Post your favourite CT5 settings immediately
Moderator: multi_s
- involved
- involved
Re: Post your favourite CT5 settings immediately
I'll start:
1) mode 1 > mix to 1 o'clock or so > quantize set to free > set pitch to just below unison > apply a max speed, minimum depth lfo > set feedback to ~ 3 o'clock > adjust len b to fastest, then dial it back till you get a real nice underwater sound.
2) classic mode 2 > mix to taste > quantize to 5ths and octaves > set for 1 octave up/down/backwards to taste > Len s to very short, but find a rhythm > set random to taste (on the low side, but depends on your input) > hold soft button for a second or less > play live into the pedal while holding soft button down with occasional strategic lifting of the button for tasty freezes / glitched up goodness. Sounds really good w/ max reverb going into the ct5, (would love a 2nd verb after it
I have more, but that'll do for now. I wanna hear yours.
What's your favourite settings? I wonder if you have found a trick which I have not...
- DRodriguez
My favorite thing I've ever done with a Ct5 and one of the few times I felt smart with it was...
Set to mode 1 with lots of feedback in parallel with a gravitas set to a rising saw wave synced to a quarter note. So that the Ct5 would swell in slowly with the beat and then sharply cut and clean up on every 1 2 3 4.
- involved
That sounds awesome. Would love to hear it.
- involved
Mode 1
Digital Delay - Quantized, non-Quantized for Mod delay, or edit LFO via newest firmware update
Mix To taste
Dir 1 2:00 (unison)
Len B 1:00 or higher (controls delay time)
FBK To taste (controls delay tail length)
Shimmery Detune-Chorus - Non-Quantized
Mix To taste
Dir 1 2:00 (unison)
Len B 7:00
FBK 7:00
Bari-trem - Quantized
Mix 5:00 (full wet)
Dir 1 1:00 (5th down)
Len B 7:00
FBK 7:00
Banjo-Steel Drum - Quantized
Mix To taste (full wet is pretty cool)
Dir 1 2:00 (unison)
Len B 7:00-9:00
FBK 9:00 and up, to taste
Oh So Pretty - Quantized
Mix 5:00 (full wet)
Dir 1 2:00 (unison)
Len B 7:00-9:00 (go further for trippy lag)
FBK 7:00
Reverse Delay/Moving Pad - Quantized, paired with another delay for more ambience
Mix Noon
Dir 1 10:00 (unison reverse)
Len B 2:00 (blue LED)
FBK 12:00 (hold soft switch for glorious pads - works well with fast arpeggiated triads)
Stutter - Quantized, hold soft switch to activate stutter
Mix Noon
Dir 1 2:00 (unison)
Len B 10:00 (blue LED)
FBK 7:00
Army of Violins - any Q setting
Mix 10:00-11:00
Dir 1 7:00 (+1 oct reverse)
Len B 1:00 (Red LED)
FBK 7:00
Crashing Planes - non-Quantized
Mix To taste, under 12:00
Dir 1 2:00 (just below unison, go just above unison for Faux Auto Whammy)
Len B 7:00
FBK To taste (controls length of dive bomb)
Dance Party - any Q setting, play simple arpeggios spanning 6th string to 3rd string
Mix 5:00 (full wet)
FBK 7:00
Mode 3
One Loop to Rule Them All - Quantized, toggle number of playback heads to add or remove "parts"
Mix To taste, controls overall playback volume (control individual head volume via newest firmware)
Dir 2 12:00 (-1 oct 1/2 reverse)
Dir 3 7:00 (+1 oct 2x reverse)
Play a Major arpeggio and incorporate the add4 note. Experiment with forward loops to add melody/harmony
Mix To taste
Dir 1 2:00 (unison)
Mix To taste
Dir 1 2:00 (unison)
Len B 7:00
FBK 7:00
Mix 5:00 (full wet)
Len B 7:00
FBK 7:00
Dir 1 2:00 (unison)
Len B 7:00-9:00
Mix 5:00 (full wet)
Dir 1 2:00 (unison)
FBK 7:00
Mix Noon
Mix Noon
Dir 1 2:00 (unison)
FBK 7:00
Mix 10:00-11:00
FBK 7:00
Len B 7:00
Mix 5:00 (full wet)
FBK 7:00
Mode 3
- involved
Whaoh! ^ treasure trove
Lookin forward to trying these ^_^
- DRodriguez
here's that setting in a full mix, so it's hidden a little by the actual beat: https://www.instagram.com/p/BBC2rTlsXmx/
Watch the gravitas tempo light or the VU meter on the space echo and notice how the Ct5 signal is constantly getting cut. If I remember correctly that was just bass, 1 guitar track, and the drum machine.
- involved
Sounds big, dude
<3
- involved
I definitely need to try that out DRodriguez! Sounds killer. What do you mean when you say they are running parallel though? From my understanding they need to be in series with the trem after for it to fully cut the volume.
- DRodriguez
Sorry, that was a bit unclear. The Ct5 and the trem are in series, the clean signal is parallel. Like so:
That way the Ct5 craziness swells in above your normal signal. Of course add in other effects in each chain to taste.
Code: Select all
|--->--Ct5-->--Trem-->--|
GTR—->--| |—->--Amp
|-->--Clean Signal--->--|
- involved
Ah ok that makes a bit more sense then. I just messed around with my CT5 and trem and was able to get the basic sound, but I'd have to rip my board apart to run them both in a parallel loop like that . It sounds incredible in that mix though.
- abio
- interested
rather vanilla setting, but i'm finding myself using it a lot.
https://www.dropbox.com/s/1z3nrqvtujzj9 ... 5.jpg?dl=0
- involved
Man, I really envy the parallel split.
Cool, @abio - is that mode 1 with a 5th up?
- abio
- interested
yes exactly!
- involved
Nice. I don't use the 5th a lot, as it then pops up to a 9? And so on. Still sounds gr8 though. Love the sound though, just need to play the right thing to make it work.
